Greetings.
I found a previously undiscovered stump along my driveway today and managed to bend the right front MMM anti-scalp wheel bracket. The wheel is fine and nothing's bent on that, but the bracket is bent downwards by about an inch. There's apparently no damage to the deck. The blades turn fine, no major vibrations. The other mounting points and hardware seem OK, although I haven't had time to remove the deck. I did mow the remainder of my yard (about 3 acres) and there were no issues.
So... how do I go about bending that mount point back into shape? Some light fiddling around with a sledge and then a jack yielded nothing. I didn't want to jack to much with the deck still on the tractor. If I remove it, what's the best practice for beating that bracket back into place?
TIA
TIA
