Bent hydraulic lines
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
320
26
23
Mobile, AL
I've got a bent hydraulic line on my loader. Fortunately, it is not ruptured. Is this something I can ignore or do I need to do something about it?
greeno
B2710 w/LA402 FEL, BL4690 hoe, RB1560, GS1560, Haban 5' sickle bar, 5' JD RC
Jul 14, 2018
187
Big Lake MN
Ignore it.
2,604
I've seen some that look like a pretzel almost, as long as not "pinched" or creased .......keep getting busy
Jim L.
856
162
Best to leave that one alone. Trying to bend it back will just add to metal fatigue, and it is functioning good now.
7,158
That's a minor enough bend that you can easily just bend it back, or leave it, it's not going to matter either way! ;)
bambam31
Apr 3, 2014
320
26
23
Mobile, AL
Thanks for the quick responses. It is not pinched and is functioning properly. I'll just leave it alone.
bambam31
Apr 3, 2014
320
26
23
Mobile, AL
bambam31,
Is there any way that you could make a guard to protect those lines?
If I could weld I would love to work on that project. I think the best way to project those lines is to suggest to the person who was operating my tractor to get his own tractor.
7,158
bambam31,
You could, but the real key is to not set the loader boom down on things, you really should never have anything in that space as the next thing it goes through is the radiator! :eek:, ;)
mickeyd
Mar 21, 2014
1,192
Guin, AL
It broke the plastic on the front of the bonnet (hood as we call it) but luckily it did not get to the screen or radiator.
mbu
260
United States
I'm not familiar with that particular loader but from the OP's picture it appears the the hydraulic lines cross just a short distance behind the bucket, thereby putting them directly in harms way. In his photo's upper left hand corner it looks to me that's the tractor's radiator guard and the hydraulic lines are well in front of that. Am I not interpreting this correctly?
mickeyd
Mar 21, 2014
1,192
Guin, AL
That looks exactly like my loader but then it should. I also have worried about the same thing.
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
A bit of channel or angle for protection may be worthwhile if you are working in brush.
7,158
My point is you shouldn't ever have material coming up behind the bucket, especially brush or stick like material, it's just a recipe for disaster!
