Battery terminal grease
Bogatyr
L4240, RTV900
Feb 16, 2020
SE Michigan
I just realized I haven't greased the terminals on the batteries in my equipment. Never have. Do I just use the grease in my grease gun, spray lube or specific battery terminal grease?
Thanks from a novice.
SDT
multiple and various
Apr 15, 2018
3,312
1,102
SE, IN
I use none.
SDT
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,729
2,069
Near Lancaster, PA, USA
I use Penetrox or equal (Noalox, etc are similar). Anti-oxidation grease. I use it at the joints between the battery terminals and the mating wire terminals. Clean them up and smear it on.
It's about as clothing friendly as Nickel-Ease:)
dlsmith
BX2230, LA211
Nov 15, 2018
1,285
874
Goshen, IN
If you ask 50 people, you'll get 50 different answers.
Use what ever you like, as long as it's non-conductive.
Personally, I use CorrosionX HD. It prevents and stops corrosion and leaves a waxy coating to help seal out moisture. I've used it on truck batteries for years, works as well as anything else I have tried.
Just my $.02.
KHW59
L-3901 Brushhog, Finish mower, road planner, box blade.
Apr 28, 2016
59
Palatka Fl
