Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Tractor use is now down to just driveway maintenance. Which is just winter snow removal. Spring and autumn grading if needed. Hauling firewood in the Spring and Autumn from stacks spread around the 40. Summer? Tractor for the past decade has more or less just sat.
The NH had an Optima since day 1. First one lasted IIRC 13 years. Tractor was used regularly. 2nd one ~10 years. Tractor use was down to seasonal like now. Optima #2 when put on the cheapo load tester noted "medium" when "fully" charged. That's when I considered replacing. Purchased a battery charger/maintainer with the 3rd Optima and just traded it in for the Kubota. Great timing. One year of use for a $269 battery.
Question #1:
Unsure if true or BS. Even if the battery starts your tractor. If on the low end it is hard on your alternator?
Probably should have charged the battery on day one to full. Took me until couple days ago to attach the charger/maintainer connector to the battery. Plugged it in. Battery was only at 75%.
Question #2:
What temperature and rpm is required for the alternator to efficiently charge the battery?
During the break-in hours I have been just lightly using the tractor. Hour meter just broke 9 hours prior to attaching the battery maintainer/charger. RPMs from low idle (~1500) to short periods maxing at 2400.
Question #1:
Question #2:
