Battery cables L4310
troverman
Kubota M4D-071 and Kubota ZD-1211-72
Jun 9, 2015
1,189
268
NH
OK, so my 2002 L4310 with 525 hours still has the original "GX" battery. It is starting fine, but I was doing some checking. The negative cable seems to be extremely stiff...like maybe all the copper inside is badly corroded? Is this normally this stiff? The positive cable feels very normal and flexible. Does the negative cable just drop down and ground to the frame / engine block?
rentthis
1,010
25
summerville,sc
don't know about flexibility but the ground cable will be connected to the frame or engine. If it works, run it until it doesn't.
