J jpinette New member Equipment bx2360 Sep 6, 2010 1 0 0 Surry, Me 04684 Sep 7, 2010 #1 I have a bx2360. How much combined weight between the tires and 3 pt hitch can I use without damaging the tractor or nulling the warrantee?
GWD Member Equipment M7040, L48 TLB, BX2200 Jan 8, 2010 792 15 18 Northern California Sep 7, 2010 #2 jpinette said: I have a bx2360. How much combined weight between the tires and 3 pt hitch can I use without damaging the tractor or nulling the warrantee? Click to expand... The manual or the specifications should rate the lifting capacity of the 3 PH. Anything up to that weight should be fine. My BX2200 is rated to lift 680 pounds with the 3 PH as a point of reference. Filled tires don't put any stress on the frame since they contact the ground.
