Backhoe Hydrolics BX23
DJmeagher
BX23
Sep 7, 2015
Susquehanna Pa
Hi. I'm not a guy who has much experience and could use some help. All of the sudden my backhoe Hydrolics won't respond at all on my BX23. I could use some advice. Thank you, DJ
7,016
DJmeagher, welcome to forum. Need more clues on your machine. But, off hand, it sound like your quick disconnects are not connected.
What were you doing when you lost controls? When was last time you used hoe?
DJmeagher
BX23
Sep 7, 2015
Susquehanna Pa
Thanks for answering. I used it a couple of days ago. I dug a 3x6 hole about three feet deep. It sat for two days. Went to use it and no response from backhoe controllers.
2,871
front end work correctly - bucket?
HST drive work?
checked fluid level?
Shadow
190
Somewhere
If it's hooked up as it should be, try replacing the female couplers on the backhoe where it connects to the tractor. Have seen more than once that they'll go bad and not let fluid flow
DJmeagher
BX23
Sep 7, 2015
Susquehanna Pa
Thanks a bunch for your help. I took Hydrolic connections off and one did come off easier than It should have. I re-connected and system is working now!
Thanks for your help..........DJ
