Backhoe Dolly
AndyM
BX25DTLB
Sep 21, 2016
454
114
Vancouver Island Canada
I was thinking of making up a backhoe dolly (BT 602 @ 617 lbs) using an old bed frame (1 1/2 angle x 1/8 thick). Heavy enough or go buy some square tube?
Thanks
Mike.O
B2650
Mar 28, 2017
109
CT
here is mine.....I don't think an old bed frame is strong enough.
Looks good! Im going to make one soon, I'll frame the base out of wood (I'm not a welder). My question is what happens when the cylinders drift? Do you have issues with that, especially the boom/stick? It looks like if the stabilizers drift, it will just rest on the BH frame, so doesn't look like drifting on those would be a huge issue?
Would it be possible to get the BH on the dolly with the anti-drift boom latch secured?
Repair
2017 L2501 - 2020 L2501
Apr 17, 2017
152
24
Lebanon, TN
I have thought about setting it all the way down the next time I have it on the tractor.
I'm sure you could have the latch on but I wanted the bucket out for more stability
Lencho
B7100hst
Jan 21, 2017
412
87
NM
Hi Andy - I think you may be OK with the bed frame, depending on your design. It is also easy to make a wooden one. My 4572 weighs about the same and it is on a 2x6 dolly. Definitely was worth the time I spent building it. The boom stays due to friction. I have tied the outriggers up to keep it compact.
bearskinner
Sep 1, 2014
925
241
N. Idaho
You can make a quick dolly with a couple HF Dolly's and some scrap OSB. Under $20 invested and an hours worth of work.
AndyM
BX25DTLB
Sep 21, 2016
454
114
Thanks all. I am having second thoughts about the bed frame idea - I could beef it up but by the time you do that I wonder if its worth it. Could certainly do wood one -already have the wheels and woodworking is a hobby (for about 40 years now). My welding is not so good but this seems like the perfect project to try and improve that, so I lean that way.
I found some heavier material in my stash but I will have to think about how I would put it together.
Thanks for the input everyone.
2,328
Don't have any pics of it, but I helped the neighbor build a dolly for his box blade. We utilized several ideas as stated above. He had HF dollies and we connected them with angle iron from an old bedframe. Kind of a cross between Repair's, Lencho's, & bearskinner's.
