coachgeo
On my back blade the hole in the lower plate connected to the blade that the pin goes into for setting blade angle is wobbled out. What are ways you folk have repaired this before?
Might be enough to get in there with a welder to add metal then re drill it out. Thinking though maybe adding a drilled out nut or tube orr?? below the plate so there is more meat for this pin to go thru?
Open to suggestions
Open to suggestions
