Back blade / landscape rake advice
GrumpyFarmer
3,976
Team,
looking for some advice from first hand product knowledge.
I am beginning a search to add a landscape rake. Main use will be seedbed preparation, rake pasture grass, maybe leaves (not sure that will work), driveway grooming, storm debris clean up
Before we get to that, I have a RBT3596 (landpride back blade) which happens to have two functions of hydraulics (not sure that is relevant) and I am wondering if anyone has swapped out a rake for the blade on the frame of the implement? Of it is possible to do simply? To me it looks like one bolt holding the blade and on, but I really don’t know. When I look for the similar landscape rake on LP site I don’t find much as it appears to be discontinued.
0. so first question has anyone done this? I’d like the function of a rake without buying the whole implement, but not sure it possible or as simple as I think it should be. Please advise.
Then my next topic if option above not possible or reasonable, then I wonder if I buy a new rake implement:
1. Is a rake more useful on a B or an MX, or really no difference just preference of machine? Why? I’ve not used and I wonder would it get more action on a B or MX?
2. In my mind I think I want on the MX and use the hydraulics which the MX has rear remotes. When you use the rake are you routinely changing the offset and / or angle and would the hydraulics be helpful in using the rake? (I am imagining I would be adjusting based on what I see behind me, but I never used one?)
2. Gauge wheels to me seem like a no brainer? Any reason not to get them? (I understand they are not cheap, but seem like functional/helpful.
3. Width. Should a rake be sized like a blade? (I assume minimum is cover the tracks, but I think I would want to that if angled as well, correct?)
Thank you in advance.
Spam Bot
Windows Computer
Aug 3, 2024
64
36
Austin, Minnesota
I have a LandPride landscape rake with a grader blade built into the landscape rake. It drops down when you need the grader blade option. You are correct; you could swap a landscape rake with your grader blade, but where would you find only the rake part? I have the manual rake, and when I find the time to add the rear hydraulics to my tractor, I will convert it to a power angle rake.
If you want to take your field preparation seriously and get them ready for seeding, consider investing in a LandPride Power Rake. I believe they are priced just North of $10,000! If it weren't for the price, I would already have one. Last fall I saw a 60-inch in like-new condition for $7,000 on Facebook Marketplace, and I gave it a thought for a minute or two.
GrumpyFarmer
3,976
i believe I can buy most any part of an assembly/implement I need thru my dealer…so I believe I can order the rake or the rake assembly. (The parts manual online has parts diagram…you can even order the frames painted or unpainted or pick your color…I did that with an implement I built)
Old Machinist
May 27, 2024
385
416
NE FL
I wouldn't consider a landscape rake for grass or leaves. It will scalp every time you go over a bump, divot, or hole. For leaves it's hard to beat a sweeper. I've had mixed results with gauge wheels and no longer use mine but they have a purpose in certain situations. If your land is perfectly smooth you may be able to control depth better with them but I can't get mine to remain smooth for 2 months after getting it that way.
For seed bed preparation a tiller would be my choice.
