B9200 Bevel gear leak
scooter_trash
B9200HST DP
Apr 15, 2026
Home
Hello all, new member here. Owned this B9200HST DP for a couple years now. Runs strong. It has a bush hog brand 1945 FEL. I use for the loader of course, and several 3-point attachments such as a tiller, box grader, wood chipper, 4 ft rotary cutter.
Last year I decided the hour meter may be unreliable as the associated mechanical tach was always flopping about like a winged bird. Found a NOS unit and installed... works great now. At that point I figured I could keep track of maintenance items better. So all the fluids were changed as a starting point. Most everything looked OK , except for the front right wheel oil. It drained out looking like a thin chocolate milkshake. No symptoms otherwise, and I typically run the machine in 4wd. Now to the point of my post.
This past winter, that front right wheel decided to spring a leak, as it sat on its trailer. After cleaning it up, the new oil (80-90 gear) looked to be seeping out from between the bevel gear housing "joint" . See pic:
I do not want to babysit this leak and just refill oil as needed. It must be fixed.
So after not finding any other exact posts on this tractor, but similar, I went ahead and started disassembly (as you can see)
At this point, I've removed the large outer drive gear from the hub, and dropped out the lower bevel gear out the bottom of the bevel case. Everything looks clean and crisp regarding the gears and bearing I've seen. Now for my questions; what should be my next step to separate the lower half of that bevel case from the upper half? I am betting that the oil seal located a bit further up that bevel shaft is the source of my leak. Also, how can I determine the reusability of the two shims that came out the bottom of the bevel case?
Thanks for any help you can provide!
Jugtown
B9200, B2710, Iseki G174
Oct 31, 2019
15
Asbury, NJ, USA
I had the same problem with my 9200 several years ago. You are correct, the seal between the two parts is the problem. Attached 2 pages from the service manual.
As I remember the shims are to adjust the back lash. I reused the shims on mine, since there was no real wear on the gears. If you need parts diagrams let me know.
jugtown
scooter_trash
B9200HST DP
Apr 15, 2026
Home
jugtown
Thank you! I guess I should invest in a service manual. Folks on eBay are pretty of proud of them...
I found the exploded parts diagrams on the Kubota site, thanks for the offer.
I had removed the assembly from the axle and put on my bench last night. So bear with me as I regurgitate what *I think* the instructions you provided say.
So
1. Tap out the bearing at the end of this shaft (not pictured well here), from the inside of the case.
2. Remove snap ring that retains the bevel gear, leaving it loose on the shaft. (done)
3. Knock out the shaft from the other end (top), and it drops out the bottom, pictured here:
Does that sound correct?
Jugtown
Oct 31, 2019
15
Asbury, NJ, USA
scooter,
I looked back on my 'notes' and realized I did this repair 8 years ago. Been a lot of wrenching since so my memory is a little foggy. But I think you are on the right track. Let me know how you make out.
scooter_trash
B9200HST DP
Apr 15, 2026
Home
scooter,
I was a little shy about wacking that shaft, but after studying the parts diagram I talked myself into it. Once I saw the shaft circlip groove move below the top of the bevel gear, I knew it was going right. Thanks for your assistance! It appears there are two oil seals on that shaft, guess I better change them both while I’m in there. As a matter of fact, I’m changing all the orings gaskets and seals I’ve had to move, and the total just for those parts from Kubota is astounding. I’m guessing this would be a 500 dollar job (at the least,) at the dealership.
Thanks again for the help!
scooter_trash
B9200HST DP
Apr 15, 2026
Home
Waiting on all parts to arrive. I’ve gotten all the assembly components cleaned, particularly gasket and oring surfaces. Do these flat joining surfaces deserve any grease ? The orings make the seal, and actually after 40 some years I guess most of these un coated surfaces looked pretty good. Doesn’t appear the factory used anything.
