B8200 tire verification
Tread
Kubota B8200d
Aug 16, 2021
South Carolina
Early to mid 80s B8200 gear 99% of work done is scraping 1/4 mile driveway of sugar sand.
Got some Carlisle Turf Pro R-3 Lawn & Garden Tire - 13.6-16 LRB/4ply and wanting to get some new fronts of the correct size for the 4wd ratio, which I believe is 1.691.
The rolling circumference is 112.8.
The fronts i was thinking about is the Carlisle Multi Trac C/S Lawn Tire 25x9.00-12, 4 Ply which has a mounted diameter of 24.9.
24.9 x 3.14 = 78.186
78.186÷112.8 = 0.6931382979
This should be good to go if my research is correct, but want to have someone else verify it.
Tread
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,140
139
Hardisty, Alberta
Tread
112.8/ 78.186= 1.44271, That will be OK
RickB
B8200 4wd, manual tran, loader, mower, york rake, pull plow
Sep 22, 2021
Bosque Farms, NM
So I did my math backwards....I can get it closer now that I can get the math right. Thanks
I've got an '87 B8200 and the operators manual calls for 24x8.50-12 for 4wd. 23x8.50-12 for 2wd
