B8200 front differential
Denny Gordon
Holly,Michigan 48442
I had to remove the drive shaft goes to the front differential on my b 8200 so that I can remove and repair the oil pan. I'm having trouble discerning what gaskets and or seals that I need. I was told that they are both shims but one appears to be a shim and the other appears to be a gasket. Any help would be great. Thank you!
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
The shim is for setting the depth of teeth contact (backlash), generally available in different thicknesses, the seal is achieved by the oring. Other end with gasket probably wouldn't matter (without looking at the actual set up for your machine.)
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
6,995
The gasket is paper/fiber, the shim is metal.
