F Freddynonose New member Equipment B7610 Jul 11, 2017 2 0 0 shawnee, ok, usa Jul 11, 2017 #1 Metal part to the right. Tractor won't start, but this seems to be the part buzzing. When I turn on accessorie or headlights. Attachments 20170711_100310_002.jpg 98.2 KB Views: 145
Tooljunkie Well-known member Lifetime Member Equipment L1501,home built carry all, mini plow blade. May 13, 2014 4,150 33 48 60 Lac Du Bonnet, Manitoba,Canada Jul 11, 2017 #2 It looks like a relay. Could be a dirty connection, i would check battery terminal and eye connections. And any other connector that could be dirty/corroded.
F Freddynonose New member Equipment B7610 Jul 11, 2017 2 0 0 shawnee, ok, usa Jul 12, 2017 #3 Thanks. I'll check all the grounds I see. Would a bad ground cause the relay to not fully engage? Cause it is ticking pretty loudly.
