B7510 won't crank
Villines
B7510
Feb 7, 2015
Oklahoma
Have a B7510. Runs and starts like a charm. Today when trying to start it sounds like dead battery or that the pto is in gear. Lights all work and dash lights work. Brand new battery. Any suggestions?
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the forum from Alabama. Did you clean the terminals before connecting the battery? Look to make sure the wire is making good contact with the terminals. Also check where it grounds to the tractor.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
My M9000 did that right after I changed the battery in it. I cleaned the post and terminals but after running all day it would start back. Lights worked inside and out but when I would try to crank it would loose everything. Cleaned the battery and cables and everything was fine. Don't have a clue but that fixed mine.
Tomcat
B7000 4WD, RS1(?) rototiller, Konik 125 ATV
Nov 19, 2014
557
Thailand
Sounds simple, but did you check all the connections? What do you mean about the pto in gear and what does a dead battery sound like?
