NoJacketRequired
Just acquired another B7510 - trying to standardize my fleet. (I know, I know - I dreamed for 35 years of owning a Kubota and now I own three of them, but one of them will soon go...)
This new tractor has a "whine" coming from the front wheel drive line. I jacked the front end up and turned the wheels by hand - the whine can be heard as the wheels are being rotated. There doesn't seem to be a difference in sound when the engine is driving them - so no change in sound from 2wd to 4wd.
I've checked the obvious - fluid level is good, looks clean, smells like UDT.
The paint has been knocked off the nuts on the right hand side where the horizontal axle transitions to the spindle. That area is also slightly wet with leaked oil, indicating it likely has been opened and not re-sealed properly. Other than that the machine is "factory new" underneath, even has the original factory hydraulic oil filter since it has less than 400 hours on it.
I'm open to suggestions as to potential causes, and $$ cost to fix. I'm busy these days so this likely will be a dealer repair...
