B7500 starting issue
jbbwv
B75000HSD
Dec 30, 2024
New Martinsville, WV
When I try to start the tractor the Oil pressure and Amp lights come on, but when I turn the key to Pre Heat both lights go out but the starter will not engage. Battery voltage is good (12.71). Any help would be much helpful.
Thanks, John
je1279
LX2610 w/ 60" MMM, LP 72" Snow Plow, EA Wicked 55" Grapple, and Woods 60" BB
Dec 6, 2020
828
581
Upstate NY
Thanks, John
I am definitely not an expert on that model (and welcome others to chime in), but I would start with checking for either a loose or corroded ground connection. I would also ensure that all of the starter electrical connections are both secure and not corroded.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,189
167
Hardisty, Alberta
Thanks, John
The starter doesn't engage in preheat.
Scm
BX23S
Sep 28, 2024
85
78
Missouri
Thanks, John
My 8200 did the same thing and all it was, is a loose connection on the battery. All I had to do was touch the + wire and it would start right up.
jbbwv
B75000HSD
Dec 30, 2024
That was the first thing I did. No help at all.
Thanks, John
8,324
Thanks, John
One thing to note: Just because you have volts doesn't mean you have amps.
I've got several batteries here that test out at 12+ volts and have very little to no amps.
Pull the battery and have a auto parts store load test it.
If the load test is good: Take a pair of good jumper cables, connect positive and negative right at the battery, then connect positive to starter same post as the original battery cable, and connect ground to a non painted metal location on the engine.
jbbwv
B75000HSD
Dec 30, 2024
I will give that a try in the AM Tues. Right now we have no power because of the wind and rain last night.
Thanks, John
BAP
Dec 31, 2012
2,873
970
Is PTO in neutral? Clutch pedal pushed in?
InTheWoods
B7510/FEL, B7100D, ZD18, ASK-R130
Nov 17, 2023
217
161
Indiana
...Battery voltage is good (12.71)....
Not enough information in that statement for it to mean much.
  1. WHERE exactly did you put the voltmeter probes to measure the voltage?
  2. Under WHAT condition was the voltage measured (e.g. glow plugs on? Cranking? key switch off? headlights on?)
You might, for example, have a battery with a faulty/intermittent internal cell connection. It'll show 12.71V with no load, but put a load on it and the voltage would drop to essentially zero. Excessive resistance anywhere in the start circuit causes similar behavior.
Or, tweaking what NIW says, "Just because you have your battery has volts doesn't mean you have it can provide amps to your starter"
Mr. Ohm has popped in to visit your Kubota - you need to find him.
Measuring voltage in different places under different conditions can reveal the root of the problem if a guy thinks it through carefully and has an understanding of the basic circuit involved.
jbbwv
B75000HSD
Dec 30, 2024
Turns out, it is the battery.
Thanks John
