B7300 Mid-PTO Leaking
ehenry
BX22, FEL, BH, 40" pto tiller, 42" Bushog Squealer, pto hole digger, B7300 w/60"
Mar 25, 2014
358
89
Canton, MS
The mid-pto is leaking and it appears to be coming from the seam where it bolts to the transmission not the shaft seal. In looking at the parts list for the mid-pto and the transmission I don't see a gasket or o-ring listed for where the mid-pto assembly mates to the transmission. Is it just a machined surface with some type sealer on it? Do the 4 bolts that hold it need thread sealer on them?
6,357
Loctite Anaerobic sealer, similar to silicone or RTV, but works better on metal to metal sealing, it's what the factory uses to seal it. ;)
ehenry
Mar 25, 2014
358
89
Canton, MS
NIW, thanks....so its metal on metal with sealer. I'm guessing all Hydro oil needs to be drained in order to reseal everything?
