B7300 joy stick 'catching'
Details 1
Afton, VA.
My B7300 loader joy stick 'catches' when it's pushed forward to lower the bucket. All the other positions seem to be operating normally and it goes down slowly when you first push it forward than after you jamb it past the spot where it catches it goes down normal speed. Any words of wisdom? I'm right in the midst of a big project with it and would like to make it easier and more user friendly. Thanks
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
Sounds like that is the float position where there is no holding it any up-down position. Usually that is where your control found it.
6,986
It's called a detent, it's used to float the loader bucket.
Don't push it so far forward. ;)
CJN8
B2650HSD, LA534 FEL, Gearmore Box Blade, Bush Hog, Cimmeron Rake
Nov 16, 2013
122
San Diego, CA
Float, it's so you don't gouge the ground under your material.
