b7300 hst no fwd or rev
hipshooter
B7300 HST
Feb 27, 2023
BUNNELL, FLA
Hello All,
I have a b7300 that stopped moving. No fwd or rev. oil level is good. took the oil feed line from just before the filter and was pumping oil. Do not know pressure.
Question is, where are the p1 2 3 ports, where can I find the tools to test, and what are the pressures I am looking for? Implements work fine.
Thanks in advance for the help,
pat
6,401
Does the clutch pedal feel good, any strange noises when you push it in?
Engage the PTO does it spin?
With it spinning does it stop spinning when you try and move the tractor?
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
If you have a range changing lever is it possible you bumped it into a neutral position?
