I’m looking for a Rear Grade blade to use on my B7200D tractor. The manual shows Rear Blade Max cutting width (60”) and Max Weight (350 lbs). I’m looking for one that will Angle, Tilt, and offset, to cut some Ditch line for drainage. I have found a IronCraft 4405 Grade Blade. The Spec shows width (60”) and weight (323lbs).
Pro and Con? Any Thoughts? Thank You
