b7200 idiot lights don't work!
mwolf
L3901, B7200, B5100e, g5200,G6200
Nov 13, 2023
11
Murrysville, Pa
recently purchased b7200 . idiot lights and gas gauge don't work. Downloaded owners manual to locate fuses, manual says on gas tank wall, left side. Nope, no fuses in sight anywhere.
So, where are the fuses and any suggestions on how to get these things to work? thanks
4,668
There is a main fuse in the cable coming from the starter. There are branch circuit fuses in a block on the bsckside of the instrument panel. Big fusecsupplies power to branch circuit block.
N3BP
Sep 20, 2016
473
202
Lebanon, PA
There are two small fuse holders up front between the battery or transmission cooler (depending if you have a gear drive or HST model) on the muffler side of the machine. If the fuses are ok, the contacts within the fuse holder may need cleaned.
The main "200A" fusible link is behind the starter (red arrow on second pic)
