B7200 clutch fork removal/replacement
daves1979
B7200
Jan 5, 2018
Cleveland,OH,USA
I have a B7200D and I have it split for a clutch replacement. I have the service manual but, it is not apparent on how to the get the clutch fork off the release bearing holder. The clutch fork and rod are not inside the bell housing, they are in the trans housing (under where the steering control is bolted). I see that I can remove the pin from the clutch rod and pull the rod out but, it seems like the clutch fork will fall off inside the trans housing that has no access to put it back together. I need better documentation/pics on how to remove/replace.
Thanks.
aschaumburg
B6200D
May 28, 2022
Chicago
daves1979,
How did you end up figuring this out, I'm at the same point now and trying to figure it out. Any advice would be appreciated!
Thanks.
