but I can't recall any implements that run on anything other than 540 RPM.....
I run a Kubota B348-7 48" mower deck off the back of my B5100E, My Tractor PTO speeds are 603 and 963 @3000 engine RPM
The manual for the B348-7 mower deck indicates PTO should be run in
second PTO gear 820-840 RPM
If the grass is a little high or wet I run the PTO in the lower speed(603) as it reduces bogging down however if the grass is short and dry I run the PTO in high speed(963 rpm)
I do not have a tachometer on the tractor so I do not know if I am running the engine at 3000 rpm but what I do is try to set the engine rpm so that it is not over revving and yet not bogging down. When all is set right the tractor and mower deck cut smooth and everything just feels like it is working right.
I know this does not answer your question about the 2 versus 3 speed pto on B7100's
Val
