B7100HST engine problems.
kerryd
BX25D,w/loader,backhoe,mowing deck,bushhog,and scrape blade
Sep 2, 2014
Mineral Bluff,GA,
I bought a B7100HST awhile back and the guy i bought it from told me it was pushing water out of the radiator. I said ok, maybe just a head gasket . I started working on it today to see if it would crank. It will turn over but won't start. I decided to do a compression test on it. I took the intake manifold off to get the adapter in(I used the glow plug hole). When I cranked it over it shot water out where the intake was. Is that a head gasket or worse?
10,362
Worse, these engines are notorious for cracking the head.
Pull the head and snap some pic's and I can tell ya in nothing flat.
You can get new heads for fairly reasonable.
whitetiger
Nov 20, 2011
3,461
1,905
Kansas City, KS
While you have the cylinder head off, measure the piston protrusion on each cylinder. There is a chance you have a bent connecting rod.
