B7100D pressure plate
IdahoNative
Kubota B7100D 4x4, non-HST, FEL 1630
Jan 12, 2022
128
47
Florida, central
Well, after splitting the tractor three times, I found why the clutch would not disengage. The WSM finger heights would not work. I had to set them 10mm higher. The pedal now travels a very short distance before the TO bearing contacts the fingers. And beyond that, it disengages the clutch.
Has anyone experienced this? I guess it doesn’t matter, at least it functions now!
6,202
That's odd. Sounds like the pressure plate was not set up correctly from the mfg.
I had something similar with a dual clutch. The second stage would not release to allow the PTO to engage. I had bought the tractor from a (big name) skid steer shop. A farmer had traded the tractor in for a skid steer because it had clutch problems. They separated the machine and did their repairs but it took a couple of months getting it back together.
I took the tractor apart two times and the second time sent pictures to a known specialist in Deutz tractors. When I called him to see if he received the pictures he asked me if I removed anything when I separated it. In fact he asked me several times. Turns out there is a spacer about 3/4" thick that goes on the output shaft first and allows the second stage to work.
25 dollar part and I separated that tractor (60 HP) two times to figure it out!!
IdahoNative
Jan 12, 2022
128
47
Florida, central
It is an aftermarket pplate. It must not have been built per OEM specs. I thought about finding spacer too. It was getting sooo frustrating, so I raised the fingers instead. Now, my output line on the hydraulic pump is leaking! Ugggghhhh!
