B7100D new radiator
DutchOrange
B7100D
Jul 13, 2023
Etten-Leur
I have a B7100D with a leaking radiator, ordered a replacement radiator to find out that the hose connections on the new are completely different, Not the same diameter and angle.
Now I'm trying to find out what part number is the old radiator, anybody has any idea? There is no number to be found on it, except in the front it says: M04-11. The bottom hose should be straight out and very short to connect to the existing pipe. See pictures.
2,601
Your B7100 is a geared model - yes?
Sdatrucking
B7100.
Aug 26, 2022
52
20
Tagalong3746
Take your new radiator and old one to a radiator shop have em change inlet and outlet tubes around prolly cheaper than another radiator
7,150
I'll bet your tractor has a water pump... someone's swapped the engine from a D750 to a D850 or D950.
So it does not have a stock B7100 radiator.
They have also swapped the radiator out for a different model radiator too,
I would take the radiator to a shop and have them swap / adapt it to the smaller fittings.
