B7100D HST Wheels/tires
kcw12
B7100HST-D
May 21, 2013
36
Eckerty IN
I have a later model 7100d HST with the 6 lug front and 6 lug rear wheels.
I'm going to guess that 6C360-50030(14x7) will fit on the front
and I found some bobcat rims 6on6 with 4 1/2 pilot will work on rear. for 10x16.5 tires
http://www.titanstore.com/info/4323C3GY
http://www.titanstore.com/info/4323D1GY
With those two tires.
I'm having issues getting the bolt pattern to my front rim. Tractors not at the house atm, and does anyone know?
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
62 x 1.464 = 90.768 divided by 88 = 1.0314 minus 1 x 100 = 3.14 %
Above is an example of the math........how it should work out.
In your case-
63 x 1.464 = 92;232 divided by 92 = 1.00252174 - 1 x 100 = .25217%
Kubota recommends 0-5%
If you get different numbers let me know, but the math does not compute on my end.
kcw12
B7100HST-D
May 21, 2013
36
Eckerty IN
also .25% kubotas 0-5 percent
but whats it matter, i have no clue what rims will fit the front of my 7100.
kcw12
B7100HST-D
May 21, 2013
36
Eckerty IN
Happened to stumble on this combo
Titan Trac-Loader in 27x12.50-15
and the HD 2000 in 20x8.5-10
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
Since you want R4s all around I suspect you have 4wd? If so, it does matter. The fronts need to pull the rear. If the rears push the front you will have internal binding in the gears and breakage will follow.
This set will not allow enough 'pull' in my opinion.
2-3% would be optimum.
5,947
I'm probably gonna go with the 27x12.50. Don't have to purchase rims front or rear.
I'm confussed???? :confused:
A 27x12.50 won't fit either rim size and if it's 12.50 wide it's way too wide for stock rims!
kcw12
B7100HST-D
May 21, 2013
36
Eckerty IN
I've 29/12.50s on it right now. Back rims are 15x10 right? If so titans catalong is saying 27.50x12.50 fit on a 10 inch rim.
5,947
You must have turf tires and rims on it right now.
Sorry, I was thinking about the Ag tires, Stock 6-12 on front and 8-16 on rear.
