B7100 trans removal - a cautionary tale
O6qFc27P
B7100
Jun 10, 2020
11
gGg631CR4zVmY+MY
I struggled for a couple of hours to remove my B7100 transmission from the rear end.
I'd done this job before, but this time, something was really stuck.
The trans would move about 3/4" forward and back, but just wouldn't come free.
It seemed like the pinion shaft (I think Kubota calls this a bevel gear) or its bearing was stuck in the rear end housing.
Well, many hours of fussing, and some possible damage later, I got it free.
The problem?
The PTO overrun clutch needs to be rotated to a particular position (horizontal) else it blocks the pinion bearing.
The fix was so simple: Just grab the PTO shaft at the back, turn it a few degrees.
<sigh>
Live and learn.
2,551
The problem?
<sigh>
Live and learn.
Good to know - I was thinking a rotation of something should help.....
Reminds me of a time when I was working on Inboard/outboard Alpha one drive..... someone placed it back in neutral before we reinstalled the lower unit...... had to be in drive to align
stuff lines up for a reason!
2,547
Thanks for the tip. Hopefully I'll never need it.
aaluck
Oct 9, 2019
946
771
Snowdoun, AL
Thanks for sharing the tip. One I never hope to need to use.
