B7100 stuck in neutral
Top notch grower
B7100
Nov 1, 2019
Grants pass oregon
I have a older b7100(70's). Everything works, engine, hydraulics, pto but if I shift it into gear and release the clutch nothing happens. Seems to be the high low shifter or the 4wd shifter aren't shifting. Any ideas???
Top notch grower
B7100
Nov 1, 2019
Grants pass oregon
It worked that day, everything was fine. Shifted it low gear and it won't drive since then. The high low shifter and the 4wd shifter has a lot of play and it doesn't feel like they're moving anything
9,689
Check that the shaft is turning with the lever and that it hasn't sheared the roll pin.
Then if that's not it, pull the shifter plate and see what you've got going on under it. ;)
9,689
Shifter plate on the 4wd or high/neutral/low Shifter?
Or do the mean the main shifter
You know I'm not really sure... I meant main shifter but I'm wondering is high low is in a different location... sorry I've been working in the cold on roofs and my house for too long, I think my brain is frozen! :p
On to the research lab!
