JRHill
Orange: B7100 Std and Woodmizer; Green/yellow JD Buck, Gator and 410j.
In addition to some wiring restoration it was time to change out the 40 year old starter. It's been sluggish for quite a while and despite battery condition, new heavy cables, etc. it has just been something I tolerated because of the replacement cost. But a week ago I saw a whif of smoke coming from its direction. OK, enough. I found this and thought to try it:
FYI, it was a new unit, not a rebuild for $65. Put it on and it zinged the old unit to life. But full disclosure, the idler pully was also a problem so I disassembled it and pulled the bearing. Popped the side shields, cleaned, washed, packed and reassembled. The smoke was not from the pulley - definitely the solenoid or starter. Also bought a new key switch which was also inexpensive:
Amazon.com: JEENDA Ignition Switch 66706-55120 for Kubota Engine D600 D850 D950 D905 D1005 D1105 V1305 V1505 Kubota B4200D B5100 B6100 B7100 : Automotive
Buy JEENDA Ignition Switch 66706-55120 for Kubota Engine D600 D850 D950 D905 D1005 D1105 V1305 V1505 Kubota B4200D B5100 B6100 B7100: Ignition Starter - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
