NO! That is the Whitehouse Products
LEFT hand rotation pump for gear driven B8200 engines.
The 5P1/41041GPO is the Whithouse Products
RIGHT hand rotation pump that can be made to fit the direct-drive B7100 engines.
It is slightly larger, the same size as the 6 usgpm pump used in the B8200. That said, in real-world use, I found it only slightly improved performance compared to the stock 3 usgpm B7100 pump. But it is an excellent and economical replacement for your damaged pump.
Here are pictures comparing the stock pump and the Whitehouse Products 5P1/41041GPO, and a picture of it installed on my B7100:
Nope, that slow boat only takes 30 days. They are still in the factory!!:D
www.orangetractortalks.com
(earlier in that same thread are pictures showing why the pump you mentioned above won't work).
And Dave is right on: if your FEL runs off the tractor hydraulics you should have 7 hoses to your spool valve set. 4 hoses to the FEL cylinders, 1 hose from the front of the hydraulic block, 1 hose to the back of the hydraulic block and a return hose to a tee in the filler under the front edge of the seat, next to the dipstick. I'm not certain, but there might only be 6 hoses in your photos.
