B7100 hst 4wd front differential bushing replacement
Countryboyballer
B7100 hst 4wd
Apr 12, 2026
Burnet Taxad
Has anyone ever had to replace the front differential bushings on their B7100hst 4wd. Just looking at the pivot pin from under the tractor it looks like you have to pull the engine please tell this isn’t true. My tractor is a 1993 yr model
10,479
It's much simpler than that, you just drop the front frame down to remove the pin, engine stays attached to the clutch housing and transmission.
Countryboyballer
B7100 hst 4wd
Apr 12, 2026
Burnet Taxad
I just hate that I just reinstalled the front diff driveshaft after replacing u joints and it’s a bitch getting everything lined up so you can drive the spring pins in that hold yokes on back in. I lowered it down and I was grabbing the jack stands out when I used the front tire help get back up the diff moved back and forth about a 1/4 in.
