torch
Part number 070, below.
I'm getting a lot of slop in the arm (060). Enough that it shifted sideways enough the centering notch on the bottom of 010 ended up riding on the circlip (130) instead of the bearing (110).
Is this as simple as removing the spring (030), bolt (100), slide the arm off and swap in a new bushing? Or is there a "gotcha" when you remove bolt 100?
