B7100 blowing smoke at breather
quinka
L245DT with FEL and backhoe, B7100HST
May 6, 2011
65
Heflin AL
Hi all, Not knowing much about diesel engines, my B7100HST (which has 1900 hours on it) is smoking blue smoke out the breather pipe constantly along with a smidgen of oil. Is it normal for the breather pipe to emit smoke continuously and oil droplets? The engine makes no unusual noises even at full throttle and uses about 1 quart of oil every 50 hours. My local dealer said "it is an older model and I wouldn't worry one bit, just run it" (maybe that was to coax me into purchasing a new model)? This tractor has been a fantastic tractor and if I have to get new engine, I may. I do push it alot however, I run the mower through 3 foot tall grass often to cut it down so I can mow it later correctly. Can anyone help with finding if it is a problem? If Vic can explain, I sure would appreciate it also. Any helpful hints would be well appreciated.
Thanks in advance quinka (Frank)
6,594
The smoke out the breather is from bad rings or valve guides and seals.
It's got a few hours on it, and your not going to hurt it running it like that, when it gets bad enough it will get harder and harder to start.
quinka
May 6, 2011
65
Heflin AL
Thanks North Idaho Wolfman, that's what the parts guy at the Kubota dealer said. In the meantime, I will search for new/almost new engine. I would like to get it rebuilt, but out here I don't know any qualified rebuilders. I will just run it until it quits, then swap engines.
Thanks,
Frank
