B7100 4Wd HST Air Filter Housing
foxnut
B7100 HST
Dec 28, 2012
11
Livingston County, MI
All,
Need some help please. My Air Filter Housing cap popped off and got ran over. Need to replace. Can't find a part number or price from Kubota. Any suggestions on where I might pick one up? Thanks - Foxnut
foxnut
B7100 HST
Dec 28, 2012
11
I saw that on e-bay and I thought that was a little steep for the housing. I will call my local dealers and see what price they come up with. I just need the Lid/Cap and not the whole unit. Hopefully I can purchase just the cap instead of the whole unit. Thanks
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
There is a used parts dealer in MI that sells on ebay. He gets Kubota from time to time.
See if you can find him.
curlycarroll
B7100HST with RC60-71HR deck, B7100DP 1999
Jun 26, 2011
Near London UK
All,
Hi, it should be:
15241-11350 Cap, Air Cleaner
15221-11410 Cover , Baffle
you may also need the hooks:
66704-85820 Hook A/C Cover
Hopefully the rubber gasket survived but if not here is the part No. for that too:
15221-11170 Gasket A/C Cover
Try Messicks for new or Wengers, the places the other members have suggested may be able to help with a used part but they are not too expensive for the cap and other parts new.
All the best,
Curly
MilkyWay
181
11
Dahlonega, GA
... Air Filter Housing cap popped off ....
The end cap may not be available as a stand-alone part. You might have to get creative and find something/anything with a diameter that is large enough but not ridiculous, drill a center hole in it, put rubber seals on it and a wing nut to hold it. Two seals actually; one between the cap and the housing and another with a flat washer where the screw holds it in place. You may have to put flat washers inside your new "cap" to hold your pre-filter (if equipped) in place as well. Good luck!
mudog88
1982 B7100HST-DT, RC60-71H MMM, 5ft. back blade
Aug 11, 2015
100
Pine Village, Indiana
The end-cap part number on the Kubota website is 15241-11160. Check with a dealer to get current part numbers though since many on their website's IPBs are superseded with new PNs. I use zip ties to hold those clips down since mine will pop off pretty easy too.
Edit: URL kept giving me trouble. Just go to this link and follow these instructions.
https://www.kubotausa.com/parts
1-Click on "Illustrated Parts List"
2-Click "View Illustrated Parts"
3-Read the Terms and Conditions, click the empty box, then click "OK"
4- Type in "B7100" then click "Search"
5-Click "Open" beside your desired tractor
6-Click the + next to "ENGINE"
7-Click on "Air Cleaner"
8- It's item #8 on the breakdown
Hope this all helps.
