B7000 tapping hydraulics
pistonbroke
B7000
Jul 22, 2013
uk
Hope I've put this question in the right place - I want to operate a log splitter off my gray import B7000.
I was hoping the yellow painted bolt under the seat was access to the hydraulics - but I'm assuming after reading Vic's excellent article that's just for topping up the fluid - and I have to cut into the side pipe and braze on connectors as per the article.
My question's this - when I stop using the log splitter the hydraulics will no longer form a 'circuit' - therefore presumably I have to fit something in between the 2 new connectors to allow the fluid to flow?
Sorry if it's a daft question to those in the know - I'm more of a 4lb lump hammer sort of mechanic.
6,603
The yellow topped bolt is for adjusting the lowering speed of the three point arms.
When you tap into the pressure side of the circuit you need to use an open center spool valve for the added control circuit, you will also want to go inline (cut and spice in series) not Parallel the circuit with tee's.
That will allow you to use the added ports and also use the three point too. Also with the open center valve you won't need to do anything with the line other than install quick disconnects to the lines to shut then when not in use.
Big Kahuna
Kubota 2000 L3010 HST with Loader ,1992 B7100HST , 1979 B6100E & 2007 F2880
Dec 23, 2011
363
Homer City, Pa.
You need a hydrualic tap block adapter
Part # 70070-00385 $73.26 U.S. price
Makes it real easy to run other equipment.
Big Kahuna
