b6200 fuel leak
Jrivas13
12
Ct
Hi guys, today while working I smelted alot of fuel and looked and saw a steady stream coming out. Shut it down and opened hood. The injectors have seems to be like small rubber hoses connecting to each. The hose closest to the dash compartment hose had popped off and seemed to be squirting out there. Should these hoses have fuel in them? and should I put a clamp on theses hoses? Thanks
bruceatlam
B20, FEL, box blade, flail mower
Aug 20, 2009
410
Camarillo, California
If I understand you correctly --- yes, the hoses continually circulate excess fuel back to your tank. That's why your tank warms up while you work. Yes, put a clamp on the hose and it's fitting.
