B6200-7200 mowing ???
garyf
B7200 MF135, MF40TLB, MF40B Loader, JD430, JD332, 3-JD318's
May 14, 2009
Lowbanks, Ontario
HI...Regarding the mowing decks on the older B series mowing tractors does the deck run on the wheels or is it supposed to be hung from the tractor and the wheels are for anti-scalp(like my JD's)?
I will be mounting a 60" deck on my B7200D(gear) and will be trying to locate the operators/installation manual to get correct setup/leveling instructions. Thanks...Gary
handyman
Kubota B7100HST-E
Sep 18, 2009
452
Dayton,Tn.
Garyf I have a B7100 it uses the wheels to roll on like your JD for antiscalping. My B7100 uses hangers and has pins on your tractor you should be able to see. It also has 2 rods adjustable from mower to rear lift. The pins on your tractor goes on the hanger brackets your mower comes with. Just arms that swivel. Sorry if this doesnt make since. If you look under tractor you will see the pins the brackets fit over and a pin goes in the hole on tractor pins to hold mower brackets on. Hope this helps. handy
garyf
May 14, 2009
Lowbanks, Ontario
Thanks Handy! that was what I thought just needed confimation. Picked up the deck today Tomorrow I will order the operators manual...Gary
