Hi, all I am new to the forums and recently purchased my very first Kubota tractor. It is a B6000E. So far I have done a bit of maintenance on it (replacing fluids, filters, replaced front seal in engine and repaired a leaking radiator). The tractor runs great now that I rewired the fuel pump (it wasn't even working when I got it and the tractor would still run!). The problem I am having now is with the hydraulics. I have drained and replaced the fluid, cleaned the filter and adjusted everything I can find without any luck. I am going to be using the tractor primarily for leveling my driveway and backyard (I have about one acre of land). I purchased a 5' scrape blade to do this with (King Kutter XB 191lbs). I think the hydraulics should be more than capable to lift it but it doesn't. It will lift maybe one inch and that is it. I have done alot of work on cars/trucks but I have never been into a tractor hydraulic system. Do you guys have ideas where I should look first? It there a pump rebuild it? I have a schematic for the tractor and it appears that many orings are involved and with the tractor being 30+ years old I would think these need to be replaced, just don't know how. Any help would be greatly appreciated. Thanks!
