Hello Everyone
Does anyone know what the max ring end gap should be or what the max/min cylinder size is for a B6000. I could not find it in my searches.
Yes I have new rings and piston and found the reason for my oil consumption (stuck and broken rings), but I want to see if a good hone job will do it before sending it out for a new sleeve.
I looked in the s.m. and it appears that they were very confident in the engine, but they covered the battery in more detail.
If anyone knows that would be great.
Enjoy Everyones posts!!
Edit: Found what I needed...if anyone needs this in the future.
Kubota Tractor Model Kubota Engine Model
B6000
ZL600
Engine Model: ZL600
Head Bolt Torque: 58
Tractor Model: B6000
Main Bearing Case Bolt 1 Torque: 18
# of Cylinders: 2
Main Bearing Case Bolt 2 Torque: 40
Displacement (CC): 577
Rod Bolt Torque: 30
Displacement (Cu In): 35.2
Flywheel Bolt Torque: 51
Bore (MM): 70
Rocker Arm Bolt Torque: 20
Bore (In): 2.76
Compression (PSI) Standard: 450
Stroke (MM): 75
Compression Lower Limit: 325
Stroke (In): 2.95
Engine HP (Net): 12.5
Valve Clearance (Cold): 0
Piston Ring End Gap (RV): 0.017
Piston Ring End Gap (AL): 0.035
Main Crank Journal (Front): 1.9659
Main Crank Journal (Center): 1.9659
Main Crank Journal (Rear): 1.9659
Rod Journals (Standard): 1.5338
Crankshaft End Play: 0.012
Front Pulley Nut Torque: 0
Cylinder Liner ID (RV): 2.7559
Cylinder Liner ID (AL): 2.764
Piston Diameter: 0
B6000
ZL600
Engine Model: ZL600
# of Cylinders: 2
Rod Bolt Torque: 30
Bore (MM): 70
Bore (In): 2.76
Stroke (MM): 75
Stroke (In): 2.95
Piston Diameter: 0
