B6000 Rear Track Adjustment?
Retread
B6000
Apr 28, 2015
Vancouver, Canada
Folks
It aprears that the rear track on my B6000 can be varied.
But nothing moves.
It could have been welded or maybe it doesn't adjust.
Anyone know?
Any pix?
Regards
Don
6,686
Go to Kubotabooks.com and download the service manual it will explain how to loosen the hubs to adjust them.
mdb6000
b6000
Oct 11, 2010
79
monroe, ct
should be fairly simple. There should be a bolt with a clevis pin in it. Remove the clevis pin and the bolt, then you will see a bolt and a spring. Loosen the bolt and the rim should slide out or in. Maybe spray some lubricant on the axle to help it slide. Find the new notch you want it to be in, place the bolt and clevis pin through the holes, and then tighten up that bolt on the spring. Hope I didn't confuse.
