I just got a Kubota B6000 13HP and I am looking for a new PTO seal and the bolts that will attach my roto tiller. Also the Seals for the rototiller too.
Messicks.com or your local Kubota dealer will have the PTO seal. I probably can't help you with the tiller but it would help to know the brand and model. Bolts I'd just get at a hardware store unless they're something special.
When you remove the old seal there should be a part# on it if not measure the diameter of the shaft and diameter of the hole ( inside and outside diameter of the seal). Any bearing supply or a Napa store should be able to help you with the seal and the bolts.
Since it bolts directly to the back of the tractor, I'm gonna guess its the same as mine with a S850 tiller. Its not bolts that hold it on, its actually 4 studs with nuts and washers. Im sure they will be metric.
The studs and the seals should be available at a Kubota dealer.
