B6000 Plow help
js5020
BX23S
Jun 27, 2018
75
PA
Howdy, I have a Kubota B6000 and I want to attach this plow to it. My buddy says it’s too big, what are your thoughts? It’s a 14” 3 blade plow. I will attach a picture of the plow! Thanks
Hmmmm no won't lift it let alone pull it. 14" plows generally require 15hp per bottom so that plow would really need a 45hp tractor at a minimum for 3 14" bottoms. A B6000 is pretty small get a single 10" like is used on garden tractors.
Bill Groom
B7100 HST
N.E. Ohio
I believe my B7100 is rated for a 14" single plow. That is a heavy piece, and would likely be entirely to large to lift, let alone plow, with. That implement would do well behind 40-50 horsepower.
Sent from my Pixel 2 XL using Tapatalk
6,264
Yes, it's much too big for your B6000. However you can take one beam out of it and make a nice one bottom plow you could probably use. Those old plows don't bring much anymore because they are not used, and the price becomes almost what ever scrap price is.
I took an old John Deere 2 bottom plow and modified it for use on my B8200. All made from scrap. Still sets there looking for work!! I removed the rolling coulter at one point and never reinstalled.
8,173
So do the mounts look correct to mount it to the b6000
Your picture comes through to us as the size of a postage stamp so little to no detail.
Regardless, that plow ain't going to work...period. ;)
Even if you cut off 2 of the moldbords it's still too big, you simply do not have enough HP or tractor to pull that. :(
