B6000 drag link joint info?
B6000ME
44
manchester
I need to replace the drag link on my b6000 Kubota tractor. The bad news is it's a discontinued part and not available anywhere. My plan is to take the drag link I have and have a machine shop add threaded ends so that I can put standard tie rod ends on to it. Does anybody know the dimension of the tapered tie rod shaft that goes through the pitman arm and the steering arm? Thanks
Aluthin
Kubota B6000
Aug 7, 2015
United Kingdom
B6000ME
44
manchester
Yes that is the part I am looking for. I called the company in your ad and they cannot get it anymore either. I'm going to have to have a machine shop add threaded ends to my link and put in replacement tie rod ends. Does anyone know the dimension of the tapered shaft on the tie rod connection?
Broadgate
B7100,B6000,tilling, backhoe, front loader
Jul 20, 2025
Devon UK
Hello,
I realise this is an old thread but wanted to ask if you located any suitable drag link ends for the b6000?
Original part number for the complete DL was 66591-56819 but long since obsolete. I am in the UK. Intention is to remove the DL from the machine and measure up and try to source some suitable replacements ends and get them welded or threaded on. Any information or experience you have on this would be appreciated. Best regards, Tom
