This post would fit well in several categories, so forgive me.
I just picked up an old Brantly backhoe that want to put onto my B6000. The tractor currently has a loader with the Kubota auxiliary pump to power that end. I don't plan on making the backhoe a quick detach or on having easy swapping to a functional 3 point hitch.
The backhoe, from what I have found, is specified for 1800-2000 psi operating pressure, markedly higher than the 1200 psi I find for the regular hydraulic pump. The loader valve is set to relieve at 800 or so psi.
What is the best way to source hydraulic power? I'm willing to put a third pump on, of course, but would rather avoid that if I can. Is the output of the regular pump higher than the relief, that is, closer to 1800 psi? I haven't found any information on similar sized domestic backhoes
as far as their volume requirements.
My loader is slower than I would like, so I am mulling over the idea of putting a single, larger pump that would feed both the loader and the backhoe.
How did the factory B619 get power?
What have others done in similar situations? Thanks.
