Hello, I picked up a B6000 4x4 with a loader and a tiller from Craigslist this winter for under $1k! The tractor was not pretty, and had a major issue. The previous owner was not very responsible, and allowed water to freeze in the radiator (ruined the core), and it also popped a freeze plug in the head. The tractor ran well, but there was a lot of oil in the radiator. So... I decided to pull the engine, and restore the entire machine. I am in the process of reassembly, but ran into a couple of issues in which I could use some advice.
1. I can't find a clutch alignment tool anywhere. Is there a standard tool out there that will work? Any tricks?
2. The manual steering box is leaking fluid around the spline seal. Does the box need to be disassembled to change it? Or can it be done without tearing it down?
3. Any advice on a good source for parts? Used (missing air cleaner), and new (gaskets, bearings and such) My local Kubota dealer is taking a very long time to look up prices for me (going on two weeks!). Also, the place is pricey!
Thanks!
Thanks!
