B3300 SU start/ restart issue
kallred
B3300SU
Sep 9, 2013
NC
I am new to forum......need advise regarding restarting problem with B3300 SU.....since purchasing tractor new in 2011 have had occasional problems with tractor cutting off when raising up from seat with tractor still running......the PTO lever is in off position when this occurs.....when I try turn the key to restart tractor the engine will not turn over....however the dash does display all the red electronic symbols. The weird thing is this problem does not occur every time I have tractor running and get off seat.....but when it does it is very aggravating as it can take several minutes before I can get tractor restarted. I originally thought the problem was being caused by accidentally putting my foot either on the forward or reverse pedal when turning the key to start .....which assume if that happens the tractor would not start due to safety feature (OPC safety device?). I had dealer look at tractor when this originally started happening (which was shortly after purchasing the tractor new) and they could not find anything wrong ......again this problem does not occur every time I start the tractor. Any body experienced a similar problem or any idea on what may be causing this? Thanks in advance for any help.
ibunker
B3300SU w/BK76, Box blade, DR wood chipper
Dec 5, 2010
52
Port Orchard, WA
Had the same problem with the OPC switch when tractor was left in the rain. It started, pressed the speed control pedal (SCP) to move it, got off and the tractor died. Would not start. I located the OPC switch just forward of the hydraulic filter and sprayed the switch activator piston from the SCP with WD 40, rocked the SCP until the piston pressed the OPC switch in, in neutral the switch is depressed. I added this little bit of maintenance to my zerk fitting lubing, since I'm under the tractor lubing. Hope this helps.
kallred
B3300SU
Sep 9, 2013
NC
I followed ibunker's instructions today while using my tractor and the problem went away..............if anyone else experiences the same problem, do as outlined ...........a BIG THANK YOU to ibunker!
3,718
Very cool one more thing to lock away in the memory banks
