B2920
WVorange
Wileyville,wv
Hello!New to the site. I'm looking at 2011 kubota b2920 with 140 hrs. Tractor has FEL, BH65 with thumb and 60" MMM. Price is $21,000. Would like to know if this is a fair price and if it is a good tractor. Thanks
WVorange
Wileyville,wv
Any help will be great as I'm planning on pulling the trigger on this tractor next week. This will be my first compact tractor as I've only owned lawn tractors in the past
8,172
Good price if it's in good shape.
It's as good as any Kubota, No known issues!
BAP
Dec 31, 2012
2,853
948
I have a 2012 B2920 with loader and 60"mm. I love it, it is a great machine. I wish I had the backhoe to go with it. I paid about $20000 for it in 2012 and did not have a backhoe. So for 140 hours and having a backhoe, I would say that it is a good deal. If it is good shape, I would go for it.
WVorange
Wileyville,wv
Thank u for the responses. If the tractor is in the same condition as the pictures he sent, then it is in like new condition.
Anything I should check out / look for when i test out the tractor? Thx again
Ezlife45
B2650
Jun 5, 2014
172
Louisiana
Is it hydrostatic? 4WD? Try driving it in all speeds, forward and backward, try engaging from 2 to 4 WD, run it offroad and turn in 4WD to listen for drive strain/damaged 4WD components. Before you start it check hydraulic fluid, look at the basics, check for oil leaks, check oil level, radiator leaks etc.
Then try the hydraulics, 3 PT raise/lower, engaging the PTO's etc.
It is a fairly new machine so chances are it does not have any problems.
