B2920 w/LA364 front loader curl sporadic and slight leak from loader valve.
Psychohada
Kubota B2920 w/LA364 Loader,Belly mower & Backhoe
Mar 10, 2022
9
New York
I bought the tractor new in 2012. I read a post here about a similar problem. I have to wait for snow to melt to disassemble, but I would like to repair myself. I'm having a hard time locating part number for the front loader control valve. Also which repair manual would have this in it, the tractor or the loader wsm? Any help would be appreciated.
Vlach7
L47 305DT JD500C
Dec 16, 2021
346
252
Frazier Park Ca
I have the 2hr curl drop issue, after looking in messicks parts, rebuild for cylinders 2x7 o-rings $250, or $3500 for a new spool/control Valves, I figured its not that bad yet, If you have a leak from the spool/control valves look at the Messicks site to see if they would have a rebuild kit for you, hopfully its just one of your hose ends needing repair or be tightened. Good luck.
Psychohada
Mar 10, 2022
9
New York
I have searched Messick's and others, they seem to list parts for every front loader but the LA364. I thought it was a fairly common model.
Psychohada
Mar 10, 2022
9
New York
The valve is mounted by the transmission, to the right of the seat.
6,378
That loader only fits 2 models so pretty uncommon.
6,378
The Loader valve is part of the tractor on that model.
The seal kit for the valve is YW368-94100
I'll send you a link for the WSM
Psychohada
Mar 10, 2022
9
New York
Do you happen to know the part number for the control valve in case it needs replacement?
Monzo
B2620
Feb 5, 2016
Iowa
I am new to this site & cannot seem to figure out how to post a new question about my Kubota LA364 Loader so thought I would post here & see if anybody can help me out. I apologize for being so stupid about this, but never had a computer 84 years ago. I have a Kubota B2620 tractor & I am having an issue with the control lever on the LA364 loader sometimes when want to tilt the bucket up/down the lever seems to stick, however if I move it a little left or right it then seems to work ok....is there something that is worn somewhere that needs to be replaced ?
Thank you in advance for your assistance,
